will the powersteering set up from an 97 ex coupe work on my 92 civic sedan? and when i say "set up" i mean the lines, the pump, the brackets, etc. any answers are helpful.
thanks
eg power steering ?
stlmadpanda
eg power steering ?
Drowzysleeper wrote:stlmadpanda wrote:of course she did
eg power steering ?
You'll only be able to use two bolts for the bracket. The other 1 or 2 bolts won't line up with the D15B block. As far as the lines and pump go, I dunno. They should work though.
