what else could it be!?
mybluesi
so my car had an oil leak. so today i got some motivation and replaced th pan gasket and crank seal... its leakin from the drivers side of the motor... what else is on that side of the motor that could leak!? anything would be a big help!
The only one from Springfield, Il
currently in Korea serving the country!
clean up the block then go for a spiried drive, when you come back look for the source. Most honda oil leaks I have seen comes from the cam seal plug, but it sounds like yours is lower and from the other side. Check out the oil pump gasket and the cam seals.
