D16 vtec problems.
No Dig
D16 vtec problems.
Post by No Dig »
Ill make it short and sweet. Bought a 92 si, had a CEL for #21 vtec spool solenoid.
The previous owner had all the vtec wiring bypassed and had vtec ran straight to ECU, I eliminated all of this, soldiered and did everything correctly from the factory orange wire with white stripe on ECU to the factory green yellow stripe wire that plugs into vtec.
Ohm checked everything from ECU, pings the guage perfect, checked all connections from wiring to plug from plug to solenoid. Pulled solenoid off, cleaned screen, gave it a small 12V jump and it clicks correctly.
CEL wont go away (obvious reset ECU) Problem is, comes in right away even with car off and doesnt go away after any ammount of driving.
I've searched just about every forum on the planet and have found no answers other then check wiring/clean screen.
any ideas would be greatly appreciated, my only thoughts are a.)solenoid is trash, or b.) ecu is possibly trashed. Has a sticker on ECU stating something about remanufactured date is from 2003 and it says void if sticker is removed making me think this may have been a problem for the car before.
2004 neon: 639/649 on 93. 67mm/150 hit
2004 zx14
1987 Grand National
No Dig
D16 vtec problems.
Post by No Dig »
also, everything on the car is 100% stock. No vtec controller or anything.
2004 zx14
1987 Grand National
ricedout
D16 vtec problems.
Post by ricedout »
hmmm... never heard about this before... but if anything else just grab another solenoild from pick n pull or sumwhere around there... then reset the ecu n see if it goes back on. if so then u got me bro
No Dig
D16 vtec problems.
Post by No Dig »
Im almost 90 % sure its the ECU. Like I said vtec sol engages like it should when hit with 12v. ohm tested all wires from wire that goes into solenoid (after plug) to orange wire/white stripe on ECU and theres nothing wrong there.
anyway, n2hifis going to bring his hatch over sunday hopefully, throw his ecu in there and give it a go, wish me luck guys.
2004 zx14
1987 Grand National
D16 vtec problems.
Post by Gunmetal Si »
good, i can chip it for u but im sure u can do that urself. good luck with it homeboy
No Dig
D16 vtec problems.
Post by No Dig »
Ohm tested everything via service manual PDF from guy on stlsr, all checked out, pulled ecu out, found big burnt spot on c15 transistor, bummer, going to take a nap and hope n2hifi calls me and is comming out to try his ECU, really wanting to get back into hondas more hardcore then i did with my white one and hoping for little to no more major problems.
2004 zx14
1987 Grand National
No Dig
D16 vtec problems.
Post by No Dig »
GUNMETAL SI;109029 wrote:good, i can chip it for u but im sure u can do that urself. good luck with it homeboy
never chipped understand how to do it but havent done it yet, heres hoping things go well bro.
Plans so far, weld in new rear fenders, slam on some slip streams, roll around for a while, then something major once i get bored.
2004 zx14
1987 Grand National
Native
D16 vtec problems.
Post by Native »
No Dig;109025 wrote:Im almost 90 % sure its the ECU. Like I said vtec sol engages like it should when hit with 12v. ohm tested all wires from wire that goes into solenoid (after plug) to orange wire/white stripe on ECU and theres nothing wrong there.
you need to try a new ecu. also i have heard that if you dont have a 4 wire O2 plug then vtec doesnt work properly. But im sure you have a 4 wire O2 being a stock si. just put a new ecu on it. p28 or a p30.
But to me it sounds like you have to try a new ecu bc, all of the other problems you have looked into silenoid, and wiring(checked with volt meter). If that all checks out then you need to get another ecu.
Go Big or Go Home!
No Dig
D16 vtec problems.
Post by No Dig »
Native;110360 wrote:you need to try a new ecu. also i have heard that if you dont have a 4 wire O2 plug then vtec doesnt work properly. But im sure you have a 4 wire O2 being a stock si. just put a new ecu on it. p28 or a p30.
bought one friday, should be here within a few hours, Im hoping that does the trick because if not im out of ideas. Speedo isnt working (at all) even with car standing still. Swapped speedo motors with one that works and it still isnt working. on the back of my ECU theres a hole burnt through some of the circuitry where the remanufacture soldiered in a new capacitor. I'm hoping this new ECu fixes it because Im almost out of ideas.
2004 zx14
1987 Grand National
