well i got my new ecu in today, i slapped it in, and waalaahh nuthin, vafc doesnt turn on, i still dont have spart, wtf else could it be?? heres a list of what ive replaced
complete msd system
distributor cap and rotor
plugs and wires
ecu
hell i tested the msd setup, it has spark goin to the dizzy, but nuthin commin out of the plug wires, im real baffled why my vafc isnt comming on, any imput would help out a lot
!!!!!!!!!!!f$#king race cars!!!!!!!!!!!!
deetz
~chris~
-scca setup 99 grand am gt
-85 cj7
-85 cj7
did you make sure you got the right spark plug wires? i knew a kid that tried using a6 plug wires on a z6 head.... didnt work.
deetz
accel performance wires for a b-series, they worked for about 12 miles before the car died on me, i was comming up an offramp and i downshifted from 5th to 2nd to slow down, and it sputtered then died, and never fired back up, kinda acted like it wanted to start a few time, and it did once, but ran like it was on 3 cylinders, timings fine, compression is still great, im down to thinkin its my ignitor or some fuse somewhere, but what would shut my vafc off and not turn it back on??,,rickles8099;81 wrote:did you make sure you got the right spark plug wires? i knew a kid that tried using a6 plug wires on a z6 head.... didnt work.
~chris~
-85 cj7
-85 cj7
i would check your ignitor pack inside the distributor or the main relay. as for as the vafc, check to make sure you didnt accidently cut a wire down by the ecu.deetz;82 wrote:accel performance wires for a b-series, they worked for about 12 miles before the car died on me, i was comming up an offramp and i downshifted from 5th to 2nd to slow down, and it sputtered then died, and never fired back up, kinda acted like it wanted to start a few time, and it did once, but ran like it was on 3 cylinders, timings fine, compression is still great, im down to thinkin its my ignitor or some fuse somewhere, but what would shut my vafc off and not turn it back on??,,
deetz
il check it outrickles8099;83 wrote:i would check your ignitor pack inside the distributor or the main relay. as for as the vafc, check to make sure you didnt accidently cut a wire down by the ecu.
~chris~
-85 cj7
-85 cj7
deetz
wires are fine
~chris~
-85 cj7
-85 cj7
were does your vafc get its power from? its prolly sumthing stupid like a relay or blown fuse maybe even a bad ignition switch...
Yeah check the fuses and if at all possible borrow someone on heres dist real quick and see if its actually in the dist its self. My buddys did the same exact thing almost to the T on what your sayin and we ended up changing everyting around back to stock and still nothing so we redid it back to before with everything and slapped a new dist in along with it and it fired right up and it run's its ass off.
We took the dist off and sent it to honda which supposebly checked it out and said it was perfect but honestly it wasn't lol so like I said borrow a dist if ya can.
deetz
i have changed everthing, including the dizzy, the only thing i havent changed s the ignitor,, i just bought one today from msd:D90CivicEx;91 wrote:Yeah check the fuses and if at all possible borrow someone on heres dist real quick and see if its actually in the dist its self. My buddys did the same exact thing almost to the T on what your sayin and we ended up changing everyting around back to stock and still nothing so we redid it back to before with everything and slapped a new dist in along with it and it fired right up and it run's its ass off.
~chris~
-85 cj7
-85 cj7
deetz
update, changed the ignitor and still no spark, when i turn my key on i hear a buzzingnoise form under the drivers side part of the dash, like an electrical buzz noise
~chris~
-85 cj7
-85 cj7
