Fuel Injector Specification Chart
Taken from superhonda.com
Injector Specifications
all those injector cant be use in any `d` or `b` engine (could nead a injector box for convert peak ans hold to saturated or vise versa)
VEHICLE Injector Types Flow Rate
1988-91 Civic si/crx si Peak and hold 240cc
1992-95 Civic si/ex Saturated 240cc
1996-00 Civic Saturated 240cc
1990-91 Integra Peak and hold 240cc
1992-00 Integra ls/gsr/type R Saturated 240cc
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 280cc
1991-up Sentra se-r/200sx se-r Saturated 265cc
1991-up MR2 Turbo Peak and hold 440cc
1988-91 Supra Turbo Peak and hold 550cc
1993-up Supra non -Turbo Saturated 315cc
1993-up Supra Twin Turbo Peak and hold 550cc
2000-up Celica GT-S Saturated 310cc
1990-up Miata 1.6 liter Saturated 215cc
1993-up Miata 1.8 liter Saturated 240cc
1993-up RX-7 Twin Turbo Saturated 550cc/850cc
1990-96 300zx Twin Turbo Saturated 370cc
1991-up 3000GT VR-4 Peak and hold 350cc
1989-up Eclipse Turbo Peak and hold 450cc
and from RC Engineering's website (www.RCEng.com) an explaination of the difference:
Do I need high or low resistance injectors for my application?
Injectors are classified into two categories.
1. High impedance/resistance (saturated) 12-16 Ohms.
2. Low impedance/resistance (peak & hold) 0.5-6 Ohms.
Saturated injectors require roughly 1-1.5 amps to open the injector. Peak & hold injectors initially needs about 4-6 amps, and once open drops to roughly 2-3 amps to keep it open.
ECU design will dictate the use of one or the other. Most late model cars will use saturated injectors.
If you would like to add to this list, I would need the years/model/impedance/flow rate for the injectors you would like to add, and if possible, a source to where you got the info. thank you.
