distributor question
Post by HardCore97 »
ok i finally got my engine in, a b18b from an 01 integra, i went to start it and it turns over but wont start. its getting fuel but no spark. is there any way to test it and see if the distributor is good before i go get a new one to make sure thats what my problem is?
deetz
Post by deetz »
check your grounds ,, theres a couple that haveta be connected on the harness to get the car to start.
~chris~
-scca setup 99 grand am gt
-85 cj7
ok il go check that
why would you get a new junk remaned dizzy from the auto parts store if it could just be your coil or icm that is bad? you can buy those seperately ALOT cheaper than a new oem dizzy.
download yourself a helms manual and then you can perform just about 114,479,468 tests that it outlines..
http://www.hondahookup.com/manuals/
2nrsOfSpringfield
Post by 2nrsOfSpringfield »
Honda OEM FTW
mike93hatch;86975 wrote:why would you get a new junk remaned dizzy from the auto parts store if it could just be your coil or icm that is bad? you can buy those seperately ALOT cheaper than a new oem dizzy.
i was thinking that today im not going to buy it unless i absolutely have to. i know it needs a new cap cuz its got a half inch hole in it which is prolly the problem but il see after i go pick one up at the store
damn it its not getting fuel like i thot it was. i took the bolt out of my fuel filter and its not getting anything through the filter. guess il check my fuel pump and see if its working
HardCore97;87292 wrote:damn it its not getting fuel like i thot it was. i took the bolt out of my fuel filter and its not getting anything through the filter. guess il check my fuel pump and see if its working
thats real easy, you should be able to hear it prime from inside the car when you turn it on (mechanical noise coming from the top of the gastank) and you should hear the main relay click (one click down in the bottom left corner where the dashboard and the d/s door meet)
yeah theres a click but the pump isnt working. guess il get a new one and hook it up to see if that fixes it. could the fuel pump be bad from the car sitting in my garage for 3 months and not running?
HondaChild
Post by HondaChild »
HardCore97;87382 wrote:yeah theres a click but the pump isnt working. guess il get a new one and hook it up to see if that fixes it. could the fuel pump be bad from the car sitting in my garage for 3 months and not running?
don't think so. Did you ever run you car low on fuel and drive around with the fuel light on? because that is able to burn up the fuel pump.
ImageUnder RE-construstion
Know your roots.
