what is the difference b18 b20??
96civic cr-v
Post by 96civic cr-v »
Ok i have a 99 b20z and on the head it has p75-8 and on my buddys LS it has p75-12 is there a difference?? If there is what is it?? i know b20 has .3 bigger lift on intake aide but, what else...
.3 bigger lift?
the b20 has .3 larger bore for more displacement... otherwise, they are the same. http://stlhondas.com/forums/showthread.php?t=6612
http://www.honda-tech.com/zerothread?id=460954
the b20z uses the same head as the p75 LS b18b...
I know that H-/t thread talks about the difference in b20's, but read it, it covers your question too
Kage87
Post by Kage87 »
96civic cr-v;85860 wrote:Ok i have a 99 b20z and on the head it has p75-8 and on my buddys LS it has p75-12 is there a difference?? If there is what is it?? i know b20 has .3 bigger lift on intake aide but, what else...
Some old info from B20vtec.com
bambam;358230 wrote:B20 non-vtec FAQ Guide
I created this guide for a couple reasons, but mainly for the reason that there is ALOT of misinformation on B20's. This thread should end all of that misinformation and confusion.
How to identify your B20 Motor:
Let's first start off by saying that ALL USDM motors will have a number after the last letter in it's engine code. The Engine code stamp can be found where the transmission and block mate at the front of the motor. The JDM motors do not have this number after the last letter. For example, a B20B1 is a USDM motor, whereas a B20B is a JDM motor.This is important to understand in determining which motor you have.
Next, there weren't any B20Z's in Japan. All the JDM B20's were stamped B20B, regardless of the year. You can tell the year of the motor by checking the year/month the head was cast in. The year is located just above the fourth exhaust runner. It is in a circle with a slash through it. Disregard the slash as it means nothing. For example a circle with a 9/8 is a motor that was made in 1998. Be careful though, as this is not a 100% accurate based solely on the year. You must also look at the month it was made. Again, it is right next to the year and will have the month in a circle with a slash through it. Just like the year, if it says 1/1, that means it was made in november, the eleventh month. I'll show you why the year is not 100% accurate. If a motor was made in 98, but was made in november or december of that year, it is actually a 99 motor. That is because they start making the motors early for the next years vehicles. If the head was made in september/october though, that is a tossup as it may either be the year cast on the head, or the next year, because that is the crossover where they stop making the current years vehicles and start producing the next year's vehicles.
Believe it or not, almost all B20's, regardless of year, come with the 96+ Integra LS P75 head. They are 99% identical. They have the same valves, springs, valve covers, distributors, cam gears, etc. as 96+ USDM/JDM P75 Integra LS heads. The only differences are w/ the variances in camshafts. There is one exception however. The B20 motor was equipped in MANY vehicles in Japan, mainly the SM-X, Step Wagon, CRV, and Orthia. Of the many B20 powered vehicles, three of them came with the P8R head, and only in certain model years. The Orthia, which came out in 1996 was one. The other was the Step Wagon. The orthia came with the P8R head in it's 96-98 model years and the step wagon came with the P8R equipped B20B in it's 96-98 model years. The CRV also came with either the P8R head or P75 head in it's 96-98 model years. The P8R head is a completely different casting than P75 heads which were used on all other B20's. This head came with 84mm combustion chambers and 33mm vtec sized intake valves.
All 99-00 B20's have a knock sensor, regardless of where it comes from
, which signifies the high compression 9.6:1 motor. If your B20 does NOT have a knock sensor, it is not the 9.6:1 compression motor. High compression B20's use "PHK" pistons which have a less of a dish them, as the "P3f" pistons found in the low compression B20's do. All B20's have an 84mm Bore and an 89mm stroke regardless of year. They are internally and externally identical to 96+ B18B's, with the exception of the Pistons, sleeves, and in some cases, the intake manifold and cams. They all have an 81mm combustion chamber diameter as well, except for the "P8R" head, which has an 84mm diameter and larger valves, as described above.
Here is a list of the different compression ratios and Power Ratings for B20's, in regards to the year and origin of the motor:
USDM:
96-98 Honda CRV
126 HP, 133 ft/lbs TQ
compression: 8.8:1
99-00 Honda CRV
146 HP, 133 Ft/lbs TQ
compression: 9.6:1
JDM B20B's (taken from Japan's Honda website):
96-98 Honda Orthia
143 HP, 132 ft/lbs TQ
9.2:1 compression
96-98 Honda Step Wagon
123 HP,133 ft/lbs TQ
9.2:1 compression
99-00 Honda Step Wagon
134 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda CRV (two variants)
128 HP, 136 ft/lbs TQ
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
148 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda SM-X
128 HP, 135 ft/lbs TQ
8.8:1 compression
99-00 Honda SM-X
138 HP, 137 ft/lbs TQ
9.6:1 compression
These power figures are worthless for you and me, in the sense that these numbers are for these motors in their respective stock vehicles. Take into account that these numbers are with the restrictive CRV header/exhaust, extremely restrictive CRV ECU with it's conservative fuel/ignition tables, restrictive CRV Intake, etc. I've seen multiple B20's dyno in the 125-140 HP range with nothing more than an intake, header, and exhaust, with torque numbers in the 130-140 FT/LBS region. Which is more torque than they are rated at to the flywheel. Based on the factory numbers, these kind of gains shouldn't be made just with an intake and exhaust upgrade. This just goes to show you how underated these motors are from the factory. There is a Rule of thumb that says whp numbers should be about 15-20% lower than flywheel rated horsepower. By using that formula, High compression B20 motors should be rated closer to 160 Hp and low compression B20 motors should be rated closer to 145 wheel horsepower.
-Kyle
"Le Bon Temps Viendra"
TurboFreak
Post by TurboFreak »
i have a page with all the specs bookmarked on my other computer ill post it up tomorrow the b20b and i forget the other one have a bigger bore than a b18 but the same stroke and the other b20's have the same bore but different stroke...i think...there is too many damn numbers to remember
Nik
Turbulent Motorsports
I have more torque than GOD!
Post by 5thgen »
Kage87;85895 wrote:Some old info from B20vtec.com......The P8R head is a completely different casting than P75 heads which were used on all other B20's. This head came with 84mm combustion chambers and 33mm vtec sized intake valves.
Kyle posted the main difference, if you can find this b20 p8r head....ls intake valves are small(er).
Post by RyanA »
TurboFreak;85896 wrote:i have a page with all the specs bookmarked on my other computer ill post it up tomorrow the b20b and i forget the other one have a bigger bore than a b18 but the same stroke and the other b20's have the same bore but different stroke...i think...there is too many damn numbers to remember
Only power making difference between a B20B and Z is the piston design. They both have the same stroke (which is the same as a B18A/B) and the 84 mm bore.
2nrsOfSpringfield
Post by 2nrsOfSpringfield »
the B20z also comes with a Vtec oil pump
