90 civic si brake problems
sukda314
Post by sukda314 »
I bought this 90 civic si w/ B18B swap and i'm having a problem brakes. the brake lights won't come on when i step on it. I checked the fuse and changed the bulb but still nothing.
ObsesionWitSped
Post by ObsesionWitSped »
Did you check the switch?
Talking about Andy's drop:
sukda314
Post by sukda314 »
no i dont know where its at
ObsesionWitSped
Around the brake pedal.
fobangn
Post by fobangn »
that'd be my guess
Post by stolle »
does your horn work? the brakes and the horn are on the same circuit so if your horn doesnt work your brake lights wont work either.
check the ground for the brake lights in the back remove the cover from underneath the latch for the hatch and make sure the ground is ok...
White91Hatch
Post by White91Hatch »
stolle;133917 wrote:does your horn work? the brakes and the horn are on the same circuit so if your horn doesnt work your brake lights wont work either.
Fuze/Ground.
HPH = Hollow Point Heroes
Post by RyanA »
Sounds like the main relay. You need to drop your gas tank to get to it.
