turbo oil lines on a turbo d motor
psychosol
how long do they both need to be anybody know.
long enough to go from the source to the destination(turbo). depending on how you route it, length may vary. also, theres only one feed line and then the return line. the return line should be freeflowing and goes straight from the turbo to the oil pan bung that you had welded in.
Just order the Stealthmode Performance oil line kit. Its $85 shipped and comes with everything you need.
http://www.stealthmodeperformance.com
JesSi
niket
the length is a few feet, i can measure for you exactly when i get home (i have a y8). basically, the longest line is the turbo oil feed line from your tee off the back of the block to the turbo, in the front of your block. my estimation is about 10 ft, because you would route it around the block. The shortest is the turbo oil drain feed, which will go back into your oil pan (a couple of feet). i highly recommend the stealthmode oil kit.
Chaos
lmao are you serious? 10 ft....for a oil feed line? fuck no.....
i have a 4ft and a 3ft oil feed line....i honestly dont know which to use yet bc i havent installed my turbo kit yet.....i think 3ft will be to short though by a hair.....im sure the 4ft line will work just fine....
a oil return line is usually less than a foot maybe around 10 inches.......unless your running a topmount turbo.....
Turbo Dohc Zc @10psi In Progress
