bsderies eg swap help
Drowzysleeper
im putting an ls into my eg wondering if i need some special cat. or if my header will bolt up to the cat converter without modification. any help would be great
IM AN EPIC FAIL
Your exhaust will bolt fine to your B sereis exhaust manifold so the cat should be fine.Drowzysleeper;48346 wrote:im putting an ls into my eg wondering if i need some special cat. or if my header will bolt up to the cat converter without modification. any help would be great
aj is correct, on his car when we did the swap the stock b series header bolted directly to his stock cat which bolted to his aftermarket exhaust
chris
chris
Drowzysleeper
is it time?!?!?!?Drowzysleeper;48458 wrote:beautiful thanks guys.
It better be :biggrin:bildo16;48473 wrote:is it time?!?!?!?
