car died
camohatch
car died
Post by camohatch »
i was driving yesterday and all of a sudden my car died. aney one might know wht it is im getting fuel but no spark. im getting power to the msd coil but no spark plz help!!!
car died
Post by rickles8099 »
check your ignition switch and your main relay.
camohatch
car died
Post by camohatch »
some one told me it might also be the distributior
car died
camohatch;41227 wrote:some one told me it might also be the distributior
could be. it could also be a short. thats the problem with electrical problems... it could be one/several of a lot of different things.
99SilverCX
car died
Post by 99SilverCX »
check your coil wire for contiuity with voltmeter, if you have a crack in it, then it won't have continuity, or try a different coil cable.
Also, check the coil output by connectin a spark plug into the end of the coil cable and hold the plug against a good ground, DO NOT TOUCH THE SPARK PLUG WITH YOUR HAND!!! if you hold the plug with your hand and your coil works, you will be SHOCKED WITH A FEW THOUSAND VOLTS!!! disconnect the fuel pump and crank the motor a few times. It is important to disconnect the fuel pump so it doesn't flood your cylinders with gas.
Do this at your own risk...
