if youve used n2o click here
big pipe
Post by big pipe »
am i guaranteed to kill a honda engine with it? i used to spray a 100 shot into a 4.3l sonoma 5 times a day for a two full years, never had a single problem. everybody says its no good for hondas, but id hate to give up on it so easily. if anybody heres actually blew their shit up as a direct result from sprayin tell me about it.
engine size
spray size
kit manufacturer
evoman33
lol
Post by evoman33 »
i did 98 honda civic ex. i hate n2o. turbo and n2o different story.
why rub your car when you can stroke the engine
co-owner of RX CUSTOMS
welcome to rx customs
wow you sprayed your truck everyday for two years???? wow man. But Chris(N2HIFI) has worked with nitrous before. He actually had a built D16Z6 on the bottle and it lasted for a while if I remember correctly.
Cfh99Hc
Post by Cfh99Hc »
I sprayed a 55shot for a good 8 months with no problems...up'd it to a 75 shot and bent 6 exhaust valves after two months....this was on a stock B16 with header and exhaust using the Zex dry kit.
Post by 90CivicEx »
Cfh99Hc;41177 wrote:I sprayed a 55shot for a good 8 months with no problems...up'd it to a 75 shot and bent 6 exhaust valves after two months....this was on a stock B16 with header and exhaust using the Zex dry kit.
That was your problem it was a dry shot...
Kolk1
Post by Kolk1 »
90CivicEx;41183 wrote:That was your problem it was a dry shot...
Thats about the most stupid comment you can make about nitrous. Yes, some how you need more fuel, but a wet kit isnt the only answer.
Might as well just said, Well, your problems is, its a econobox.
1 Hyundai + 1 Kawasaki = 558whp 519wtq
civic4life13
Post by civic4life13 »
i blew my d16 with it after 2 shots just got it put in and 10 min later the every spark plug was melted and the head was shot had to rebuild the whole damn thing i was using a zex dry kit with a 75 shot
Poker
Post by Poker »
i spray a lot. it works very good on integras.
1.9
100
zex
Jar Jar Binks
Post by Jar Jar Binks »
Poker;42762 wrote:i spray a lot. it works very good on BUILT integras.
1.9
100
zex
Fixed
