type r and eg
Clayton
type r and eg
i have the booster, master cylinder, and proportioning valve off of a 98-01 usdm type r integra and was wondering if it would fit on the hatch. i think it will but am just double checking. the reason i am asking is the master looks like it goes \ instead of normall like / and now after doing research its possibly not a type r b/c it is not flat b/c it looks like -. ill takae pictures when i get home.
type r and eg
lol ok :goodpost:
Clayton
type r and eg
well it became complicated when i started doing research so :flipa:Phate;61746 wrote:lol ok :goodpost:
type r and eg
Yeah, i was just messin.06sik20z3;61748 wrote:well it became complicated when i started doing research so :flipa:
type r and eg
I get what your saying and its a really good question but if ya ask me it should work cause you are replaceing the booster and master cylinder at once so you won't be unbolting the master cylinder to put on your EG ya know. But looks like I'm gonna have to do some research on H-T and some other sites for ya as well, this could be a really good discussion in the end.06sik20z3;61738 wrote:i have the booster, master cylinder, and proportioning valve off of a 98-01 usdm type r integra and was wondering if it would fit on the hatch. i think it will but am just double checking. the reason i am asking is the master looks like it goes \ instead of normall like / and now after doing research its possibly not a type r b/c it is not flat b/c it looks like -. ill takae pictures when i get home.
MLRtimeSTL
type r and eg
If your hatch has abs then yes the PV should work...but if you don't have abs you need a non-abs PV.
