im not sure if i need a new left rear brake caliper (driver side) or a rebuild kit.
basically when i release my e-brake my rear caliper sticks a little bit and drags. the passenger side releases just fine with no problems. could it be possible that the return spring is worn out?
any help is greatly appreciated.
-andrew
rear brake caliper problem!!!
isnt there shoes on the inside of the disc itself? common on most cars equipped w/ rear discs, not sre on this xact one though.
v-tecivic
forgot to mention its on my civic. the rear caliper piston and e-brake are one in the same.
i think what you were refering to is a drum in hat, where the e-brake is designed like a drum brake with a seperate caliper for the normal braking on the disc portion.
