Retard in rush hour
SlowCRX
Retard in rush hour
Post by SlowCRX »
This retard tried to get me to race him in rush hour with his broken ass car needing a ring job and a camber kit. Had to roll up the windows or I wouldve choked on the 007 smoke screen. Who races in damn near bumper to bumper traffic?
MidMoMOFO Built
OMR (OneMan Racing) Because we CAN do it ourselves....
Retard in rush hour
I can't wait to see how this ends. The pop corn is in the microwave...
ryansDc5
Retard in rush hour
Post by ryansDc5 »
Rob knows something we don't know! I wanna know!!
'05 NFR s2000
gsrauto98
Retard in rush hour
Post by gsrauto98 »
ryansDc5;227160 wrote:Master Obi Wan knows something we don't know! I wanna know!!
Fixed for you!
And i wonder who this was...must be somebody on here.
Fenian
Retard in rush hour
Post by Fenian »
It looks like Liquor Assassin, the front wheel cover and the sidemarkers look the same. If I'm wrong, sorry for mistakenly identifying you.
'05 Subaru Outback Sport SE m/t
Liquor Assassin
Retard in rush hour
Post by Liquor Assassin »
it was me... that was no more then an hour after getting my clutch fixed more or less just fing around cause i havent been able to downshift in 4 months, and its a loose cat , comp is 210 across the board,the smoke could either be the fact im running a type-r basemap on a gsr or that i have a leaky valve seal, im curious though... does that hood scoop serve any purpose... at all?
Member #1 of stl honda's classic car club
SlowCRX
Retard in rush hour
Post by SlowCRX »
Liquor Assassin;227167 wrote:it was me... that was no more then an hour after getting my clutch fixed more or less just fing around cause i havent been able to downshift in 4 months, and its a loose cat , comp is 210 across the board,the smoke could either be the fact im running a type-r basemap on a gsr or that i have a leaky valve seal, im curious though... does that hood scoop serve any purpose... at all?
Well a hood scoop is an upraised component on the hood of an automobile that allows a flow of air to directly enter the engine compartment. It has one opening only and is closed on all other sides. Its main function is to allow a direct flow of air to the engine, hence the need for it to be upraised so as to effectively channel air to the engine compartment, and thus to enhance performance in several possible ways. So yes it does serve a purpose and does work.
MidMoMOFO Built
Retard in rush hour
You do realize that the locaton and height of your scoop leaves it a dead spot on your hood. You are getting no more HP out of that thing than a SRI
Liquor Assassin
Retard in rush hour
i could understand if it was over the intake... drop looked good, the altezzas and projectors gotta go though... as for the camber on my car, chris used to have some work's on there, i'll see if i can find a pic
SlowCRX
Retard in rush hour
Post by SlowCRX »
Hood scoop worked on my old intake (which is on the passenger side, you must of had the sun in your eyes) that I just took out because I upgraded to the famous whale dong. But it still brings nice fresh air to that compartment. I like my lights all the way around so I think I`ll keep them, but maybe that`s why I bought them.
MidMoMOFO Built
