help need info...
lil' man
help need info...
like the title says i need to know what obd the vtec sols are and if anyone has a parts sol with a good front clip im about to get a sol but it needs some stuff in the front like radiator support and all that the i wanna out a SOHC d series in it but i was a vtec sol so what obd harness do i need?
help need info...
depending on the year its either obd1 or obd2. 92 - 95 del sol's = obd1, 96 - 97 = obd2. but i believe all the sohc vtec solenoids have a grey square single wire connector.
lil' man
help need info...
its a 92-95 i believe and it had the vtec motor the b16 not vtec d16 sorry bout that...
help need info...
That would probably be an Si then. Easy way to tell, if someone has not swapped the bumper cover, is the OBD1 cars have the fogs between the headlights and the OBD2 cars have no fogs there...
Ryan
Ryan
