I just my new camber kit in
http://www.spcperformance.com/PROD_DIR/ ... 2160&cmd3=
I was wondering those of you that have camber kits, what are you running for camber,caster & toe?
This is for my CBP Sol, it's only a weekend cruiser, and I'll probably attend a auto-x and maybe a few HPDE's if the opportunity presents itself.
I was thinking of running caster 1 degree + than stock. might not be as easy to steer but I'll need less overall camber for cornering, camber will be in the -1.5 degree range. and about a 1/8" of static toe out. I have a shop that will set things to any setting I specify so I covered there, no "we have to set everything to factory spec"
Thanks for any input
