89 crx hf 5 speed, bone stock.....im torn! what should i do?
dohc zc
b18a1
d16 sohc vtec
please help
to B, or not to B?
big pipe
to B, or not to B?
im starting to lean that way, from what i hear it all just bolts right up...
btw im in florissant and i see you all the time
kikoy
to B, or not to B?
d16z6 swap and turbo it. like cool people do
Jar Jar Binks
to B, or not to B?
stay d series.. no need for the B series for the power id be guessing you would be lookin for....
budget_crx
to B, or not to B?
well, the original post contains no information about your plans for this car, but based on the motors you listed, you have a very low budget, and no real plans to make a bunch of power. So, that in mind, I would tell you to stay d-series, b-series swaps are only worth it if you:
1) plan on using the swap to build upon (IE turbo, built N/A, etc.- high horsepower applications) a d-series can be made to do or even outdo a stock b-series motor without a whole lot of effort/money.
OR
2) the whole swap is available for dirt cheap- motor, tranny, ecu, axles, mounts, shift linkage, etc, etc. and by cheap, I mean like $1000-1500 for EVERYTHING
OR
Leprechaun86
to B, or not to B?
If your gonna keep the car go B-series.
