my car still pulls to the left!!
Post by stolle »
i had both my tie rods replaced and an alignment it my car stills pulls to the left, rotated my tires checked the tire pressure still pulls weird thing though sometimes it goes straight then it goes left, err. any ideas anyone?
Team NOCO Crew Member #2
TurboFreak
Post by TurboFreak »
bah thinking... grooves in the road???
Nik
Turbulent Motorsports
I have more torque than GOD!
Bad rack?? the guy might have slit sideways into something trying to FF drift and fucked the rack up as a whole. also check to see it the rack is loosly mounted on the car.
Post by stolle »
TurboFreak;14652 wrote:bah thinking... grooves in the road???
does it all the time, so bad that i would change lanes and smack the median if i let go of the steering wheel. so i dont think its that...
btlfedgolf;14653 wrote:Bad rack?? the guy might have slit sideways into something trying to FF drift and fucked the rack up as a whole. also check to see it the rack is loosly mounted on the car.
thats next, everything seems tight just havent looked at it that closely. theres no play in the steering wheel at all. this is pissing me off!!!
modthesol
Post by modthesol »
maybe u have a bent part somewhere or bad tech
Ef-it
Post by Ef-it »
werd on the bad tech, if it was a good tech he would have test driven it to ensure no pulls or drifts. If there was still pulls or drifts present he would have told you what part was faulty or suggested what could be done otherwise. Some alignment techs that slam out cars align by the theory of "it it don't break loose i ain't adjusting it." They fudge the specs of the after print out by holding whatever was out of, into spec for the print out or just adjust the alignment heads to read that it has been adjusted.
Post by stolle »
Ef-it;14686 wrote:werd on the bad tech, if it was a good tech he would have test driven it to ensure no pulls or drifts. If there was still pulls or drifts present he would have told you what part was faulty or suggested what could be done otherwise. Some alignment techs that slam out cars align by the theory of "it it don't break loose i ain't adjusting it." They fudge the specs of the after print out by holding whatever was out of, into spec for the print out or just adjust the alignment heads to read that it has been adjusted.
i agree, but when i got the car back it was fine then half way home on the highway it started pulling again :dunno: i noticed 10 extra miles on the odometer when i picked it up so they did drive it...
Ef-it
Post by Ef-it »
I'll put ten miles on your car and tell you it's fixed, I have time...lol j/k!
I would recommend taking it back, if they're a reputable shop they will look at/ correct it for you no charge.
Post by stolle »
Ef-it;14694 wrote:I'll put ten miles on your car and tell you it's fixed, I have time...lol j/k!
lol, they put new tie rods on i checked before i left the lot :dunno:. i hope they fix it i hate taking my car to shops for this reason, but i cant do alignments...
maybe you're too fat and the extra weight is throwing the car off balance :dunno:
j/k but this sounds kinda fishy...
