how hard to fix the cracks in a carbon hood?
the gelcoat/clear coat is cracked...
how hard?? crack ing gelcoat
95_gsrfodo
4 Doors = More Whores
Not easy. You can try sanding and standard clear, but to do it right you would need to get re-gel coated. A boat repair shop should be able to help you with it.
95_gsrfodo
cant do it myself so sounds costly..Waffles;298729 wrote:Not easy. You can try sanding and standard clear, but to do it right you would need to get re-gel coated. A boat repair shop should be able to help you with it.
unless i just fix it and paint match it to the car..
