carbon hood repair?
91TEGDA
carbon hood repair?
Post by 91TEGDA »
my carbon hood looks like shit, it is starting to peel and is really oxidized. can it be repaired and if so does anyone know how to do it?
Landon353
carbon hood repair?
Post by Landon353 »
Wet sand the clear coat as far down as you can without actually getting to the carbon fiber. My hood had horrible oxidation but after i wet sanded her down and re cleared it it looked brand new. I dont remember exactly what grit sandpaper I used but it was very fine. Wet sand it for a while, then rinse it off, and repeat. Then once you have gotten down pretty far use prep solvent and then clear her :). Any local body shop should be able to clear it if you dont know how to spray or dont have materials. I could spray it for you but I no longer have a gun or booth :(. (Google restoring clear coat and i think a thread comes up on hondatech.....very good tutorial). Hope that helped
1999 Integra--Boosted at 8psi.....Garrett t3/t4, Precision 525cc, Greddy Trust front mount, Tuned on Hondata s300 by Revline Motorsports.
1965 Stang--Restoration project
03 Honda CBR 600RR
91TEGDA
carbon hood repair?
Post by 91TEGDA »
thank you
CmeltoN
carbon hood repair?
Post by CmeltoN »
If you do it yourself don't use too fine grit sandpaper or the clear will just flake right back off....the finest I would go is 1500 and that's pushing it lol
Landon353
carbon hood repair?
Post by Landon353 »
CmeltoN;253390 wrote:If you do it yourself don't use too fine grit sandpaper or the clear will just flake right back off....the finest I would go is 1500 and that's pushing it lol
Yes good point, sorry i left that out :ohnoes:
03 Honda CBR 600RR
spoon_fed_civic
carbon hood repair?
Post by spoon_fed_civic »
i did my hood with headlight restore kit.it worked pretty good,looked brand new.
91TEGDA
carbon hood repair?
Post by 91TEGDA »
right on well if anyone would like to give me a hand in doing so it would be appreciated
FTS EVO
carbon hood repair?
Post by FTS EVO »
I have fixed this problem a few times now. What I have noticed that has worked the best is to take it down to the carbonfiber, you can tell when it hits the carbonfiber the look will change, like if you would go through clear coat on paint. After you hit that you dont want to go any farther. I used 500 grit until I hit the carbonfiber, then cleared. There is no need to really go higher than that the clear will take care of those scratches no problem. You can go a little higher if you would like but I wouldn't go over 800, then clear.
97tegra
carbon hood repair?
Post by 97tegra »
I had my hood redone, the guy used a razor blade to chip off the clear. Here is a link, he is located in Springfield, Mo tho..
http://truformonline.com/viewtopic.php?f=7&t=332
