91 prelude and 15X7's
91LewdDriver
i have a 91' lude and i just got a nice deal on some15x7's im kinda worried about the 7inch wide issue, what will i have to do to get them in the wheel wells? please help, thanks.:nervous:
404 - If you are reading this message, then the message has loaded correctly. However whatever you really wanted to see has not. Have a good day.
RSXSLVR79
I think you will definately be running a bit on the wide side. I have 15x6.5 and my offset is perfect on my 88 lude.
01 S2000 (Stock...for now)
15x7 is pretty common for aftermarket wheels on hondas... you should be fine. whats the offset?
91LewdDriver
would i be able to tell if i am going to have problems with them if i just put them on before putting tires on? or is it just the wheel fitting on that would be the problem?
91LewdDriver
here they are by the way
Kage87
It would help to test fit them w/o tires to make sure you have clearance between the calipers and the rest of the suspension components. But you really can't judge final fitment till you have tires on there and put load on the suspension to see it it rubs anywhere during suspension travel.91LewdDriver;122663 wrote:would i be able to tell if i am going to have problems with them if i just put them on before putting tires on? or is it just the wheel fitting on that would be the problem?
ninja edit: if they fit those rims will look SICK on your car!
-Kyle
"Le Bon Temps Viendra"
