How to Remove a CRXs Doorpanel
http://www.honda-acura.net/forums/sh...d.php?t=128574
:FAQ: How to Remove CRX / Civic Steering Wheel
http://www.honda-acura.net/forums/sh...d.php?t=128573
:FAQ: How to Remove CRX Door Sill (56K Death)
http://www.honda-acura.net/forums/sh...d.php?t=128575
ZC Info
http://hometown.aol.com/nosajuf/nosajuf2.htm
http://www.thezcresource.com/
D15b Info
http://asia.vtec.net/article/d15b/
General Swap Info (ZC, B series, CRVTEC)
http://phatwhippincrx.20m.com/
http://tech.hybridgarage.com/
How to Identify First and Second gen B16A's
http://asia.vtec.net/topics/b16aver.html
B Series Cam Information
http://www.allmotorhonda.com/techpages/camspecs.htm
JDM B16A Information and 4th Generation ECU Pin Outs
http://b16a.honda-perf.org/theswap.html
How to Swap a Z6 Head Onto Your A6
http://crx.honda-perf.org/articles/z6swap/z6swap.html
More Information On Swapping D16Z6 into an EF
http://www.geocities.com/bing_bong916/vtec.html
OEM Injector Specifications
http://www.allmotorhonda.com/techpages/injector.htm
DPFI to MPFI Fuel Injector Swap Guide #1
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
DPFI to MPFI Fuel Injector Swap Guide #2
http://www.geocities.com/teampimports/fuelinj.html
DPFI to MPFI Fuel Injector Swap Guide #3
http://www.geocities.com/c_rexboy/mpfi.html
DPFI to MPFI Fuel Injector Swap Guide #4
http://www.bladesilver.net/crx/
ZC L3 Transmission Information
http://tjshondas.20m.com/l3.htm
B Series Transmission Information
http://www.allmotorhonda.com/techpag...anny_specs.htm
http://thenew.gamesbbs.com/~dmoore/tranny.htm
How VTEC Works
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
Transmission Rebuild
http://www.angelfire.com/on4/crxpage/transmission.html
ECU Tuning and ECU Info
http://www.hondata.com/
4th Generation Civic SiR Gauge Cluster Installation
http://www.geocities.com/MotorCity/G...1/cluster.html
How to Check ECU / Engine Codes
http://www.c-speedracing.com/faq/06.php
http://www.allmotorhonda.com/techpages/codes.htm
How to do a Rear Disc Swap
http://www.geocities.com/CapitolHill.../Disc2Drum.htm
Cruise Control Installation
http://tjshondas.20m.com/cruise.html
Front Brake Upgrading
http://tjshondas.20m.com/xlfronts.htm
Rear Brake Upgrading
http://tjshondas.20m.com/rrdisc.htm
Fixing Sloppy Shifting in Transmission
http://www.angelfire.com/on4/crxpage/shift.html
84-91 CRX Information
http://www.crxsi.com/resources/
http://quickhonda.net/index2.htm
84-87 CRX Specs & Performance
http://kumo.swcp.com/synth/crx/specs.html
84-87 CRX Analysis & Care / Pros & Cons
http://kumo.swcp.com/synth/crx/analysis-care.html
Suspension FAQ:
http://www.korywilcox.net/files/sfaq2.pdf
Various links:
http://www.jspecautosports.com/TechCenter.aspx#Honda
