I was pulling some codes off my Girlfriends 02 Cougar V6 and ran across some I have never seen nor can I find by google
P0305 - Misfire in Cyl 5
P0100 - MAF
P2000 - ???
B2080 - ???
B2004 - ???
Anyone know what they are?
EDIT: I looked up P2080 and it is a stuck IM runner and P2004 is an EGT probe. SO I guess that could be the issue, but why would they come up B?
Odd OBDII codes
99PreludeSh
Odd OBDII codes
ok just searching online this MIGHT be it
P2000 NOx Trap Efficiency Below Threshold bank1
Let me do some more searching for ya
Odd OBDII codes
Pxxxx codes are engine/ trans relatedbtlfedgolf;92813 wrote:I was pulling some codes off my Girlfriends 02 Cougar V6 and ran across some I have never seen nor can I find by google
P0100 - MAF
P2000 - ???
B2080 - ???
B2004 - ???
Bxxxx codes are body related
Uxxxx codes are communication codes.
Odd OBDII codes
Got it.andyjt;92861 wrote:Pxxxx codes are engine/ trans related
I am thinking she has an electrical issue(maybe bad ECU), the codes keep changing. I will reground the car and go from there.
Odd OBDII codes
def check all pcm grounds and connections before replacing it, does it run fine, shitty? is her mpg's suffering?
Odd OBDII codes
The plug wires were arcing causing the CAS to go nuts throwing all thoes codes. Changed plugs/wires and its all gone.
