test pipe
camohatch
test pipe
Post by camohatch »
just wondering which one to use because orf my b18 swap thanks
test pipe
You can buy my Omni Power 2.5 inch test pipe :D
Guest
test pipe
Post by Guest »
i had mine made. do you plan on staying n/a? if so, go w/ 2.5.
camohatch
test pipe
Post by camohatch »
but for which car crx or acura
test pipe
doesn't matter, it'll be the same thing. 2bolt inlet side and 3 bolt outlet... just make sure it has the holes for an O2sensor if you are running a second one.
test pipe
Its for 88-00 Civic/CRX w/ a 2.5-inch collector on the header. I think it fits Integras too.
JVolsch
test pipe
Post by JVolsch »
It may be different. I was running an omni power. I just installed the profab header, and it was way to long. I had to have the flanges cut off and make a new one that is 11 5/8 inches long. I'll probably be changing this up soon, as I really need a flex pipe on it/ second O2 bung on it. Basically measure the distance you need, and you can always have a shop fab one up for ya.
