Maybe someone knows whats going on here? Because I don't.
It started doing this about three weeks ago. The dash lights that come on with the headlights (HVAC and cluster) started flickering, going dim then bright and sometimes turning off entirely for a few moments. It got worse until now they are gone entirely, with the exception of flickering once last night while I was driving but they didn't stay on. Its not a fuse and its not just the cluster being burnt out because its the HVAC controls and such too. Every interior illumination associated with the headlights being on.
irritating dash light issue
luthoro
"Another flaw in the human character is that everybody wants to build and nobody wants to do maintenance."
Rollin on 18 wheels all day every day.
94 Honda Accord, the daily- rebuilt F22 VTEC, OBX exhaust, Ractive header, stage 1 clutch, lowered. Temporarily on lease to a friend.
85 Ford F250, the project- 460 big block, now driveable!
Sounds like the dimmer switch is bad.
gcef89
if not the dimmer switch check for a loose wire
that1028guy
I have had this same issue with my 94. Worked, flickered, didnt work. After sitting for 2 months or so, went and drove it the other day, and there back working for now. I tried to bypass the dimmer switch, and still couldnt get them to work. I believe my issue is a broken wire/bad ground somewhere. To cold to worry about it right now tho...
that1028guy
Update
I finally got some time to go mess with the acorn. After pulling almost the whole dash out, I found my issue by accident. If you disassemble the dimmer switch ( 2 gold screws, and the housing pulls apart) and jump the middle and right (closest to the steering wheel when installed, has a black wire going to it.) terminals, my dash lights worked again. so I put a spot of solder between them as a temporary fix till I can aquire a new dimmer. Note that you will not be able to dim your dash lights, but its better than guessing how fast your going. Hope this helps!
Ej
Ej
luthoro
yeah that is helpful info thanks brothat1028guy;286228 wrote:I finally got some time to go mess with the acorn. After pulling almost the whole dash out, I found my issue by accident. If you disassemble the dimmer switch ( 2 gold screws, and the housing pulls apart) and jump the middle and right (closest to the steering wheel when installed, has a black wire going to it.) terminals, my dash lights worked again. so I put a spot of solder between them as a temporary fix till I can aquire a new dimmer. Note that you will not be able to dim your dash lights, but its better than guessing how fast your going. Hope this helps!
Ej
delslo
Great update!that1028guy;286228 wrote:I finally got some time to go mess with the acorn. After pulling almost the whole dash out, I found my issue by accident. If you disassemble the dimmer switch ( 2 gold screws, and the housing pulls apart) and jump the middle and right (closest to the steering wheel when installed, has a black wire going to it.) terminals, my dash lights worked again. so I put a spot of solder between them as a temporary fix till I can aquire a new dimmer. Note that you will not be able to dim your dash lights, but its better than guessing how fast your going. Hope this helps!
Ej
