I noticed my condensor fan will not shut off when I turn my car off. I literally can start it and shut it off and the thing will run the battery dead. I have been just un-hooking the battery each time, but its annoying.
I have checked the relays and fuses under the hood. I switched the fan relay with the power window relay and it did the same thing, and obviously if I pull the relay it will stay off. The condensor fuse is good along with the radiator fan fuse obviously. I did notice that the radiator is new, but Im not sure how you can mess something like that up. The other thing is that I was wondering if both relays were bad for the Windows and the A/C condensor so when I switched them it was the same result. Anyway I have no clue what to check, so please give me some advice.
thanks-Zach
1994 Accord LX 5speed f22 A/c fan staying on?
zrs6v4
Story Worm
Have you checked the switch?
zrs6v4
Im am going to be honest, I havent. I really havent had any experience with how fans are wired, but how can I do that?
tommygun89hb
hey zack give me a call and if you are going to pic up parts tonight ill help you with your fan....
zrs6v4
thanks, sorry I didnt get back to you I was in school until 9:30 and didnt want to call that late. Ill call tomorrow and if its cool come ou to get the stuff. thanks, Zachtommygun89hb;158296 wrote:hey zack give me a call and if you are going to pic up parts tonight ill help you with your fan....
zrs6v4
Ok I still am having issues.
The relay seesm to be fine I believe after switching it we another and having same results.
I unplugged the switch, but it seems to still run off the relay. it surged after I unplugged the switch but then began to run steady off of the relay.
am I missing something here?
