New Boosted Lude member
94ludesistl
Post by 94ludesistl »
94lude h22 boosted, built eng, daily driver, lower boost, 325whp.
You do not have the required permissions to view the files attached to this post.
gcef89
Post by gcef89 »
welcome
Andrew
Post by Andrew »
Specs on turbo setup?
sharpie
Post by sharpie »
That piping looks ridiculous. Welcome.
Anything Honda
Post by Anything Honda »
Welcome
Street racing is not a crime its a life style! :vtec228:
v-tecivic
Post by v-tecivic »
welcome to the board!
97 civic ex turbo
13.1@112
Sparky65
Post by Sparky65 »
Ohh sexy. Welcome.
Also, nice JDM one piece black housing headlights. Jealouss.
- 1993 Honda Prelude Si
94ludesistl
Thanks all!
ARP head studs
Inector Dynamix ID1000cc injectors
Cometic 87mm head gasket MLS head gasket
Hondata 4bar map sensor
Mahle piston set
H beam rod set
balance shaft elimnator kit with oil pump, manual tensioner kit
valvetrain- springs, valves, retainers, seals, etc
Hondata s300
Hondata boost solenoid
boost control toggle switch (low/high boost switch)
fuel pump walbro...?? spelling unsure of at the moment
turbonetics t3/t4 hybrid ceramic bearing
cast iron manifold
turbonetics wastegate
fabricated downpipe with integrated dump
tein coilover superstreet
some low budget sway bars, uppers
low boost 6lbs+
high boost 14lbs+
dry intercooler..wants a liquid one...soon
carbon fiber hood vented and appears to be functional, hood pins..etc
next steps, body work and some paint
94ludesistl
forgot to add this was not an easy build and still working thru some bugs.... and spent way more $$ than expected.... :cheers2:
Sparky65
Post by Sparky65 »
please get a front lip. the lip and intercooler and piping would set off that front end so well...
