92 Accord Rear Disc Brake Conversion
BigMike_Accord_92
Post by BigMike_Accord_92 »
I want to change my rear drum brakes to disc brakes. How do I go about doing that?
big pipe
Post by big pipe »
go to taylors junkyard and pull the rear end out of a ex or se cb7 that has the rear disks.
check out www.cb7tuner.com
they should have everything, and anything you could ever want to know!
this space for rent
slowagon
Post by slowagon »
yup, swap is easy as hell...just pull the swap from the donor car-don't forget ebrake cables. pretty much plug and play. If your car has abs look for an abs donor-if not it doesn't matter if the donor has abs or not.....
