Posts: 2973 Joined: Fri Jun 22, 2007 4:11 pm
Post
by Capt'n Obvious » Fri Jul 30, 2010 8:16 pm
02Type-S
Posts: 3513 Joined: Thu Jan 17, 2008 10:21 pm
Post
by 02Type-S » Fri Jul 30, 2010 8:33 pm
Nice work! Can't really call it an ASR diy tho lol
I DETAIL CARS - PM ME
2002 Acura TL-S
1998 Acura Integra Skunk2 - Blox - Blackworks - Injen - DDM - Konig
Team Arsenic - Vice Pres.
Post
by Capt'n Obvious » Fri Jul 30, 2010 8:44 pm
ok jdm itr rear sway adapter brace
jpciii
Posts: 442 Joined: Fri Aug 31, 2007 4:23 pm
Post
by jpciii » Fri Jul 30, 2010 9:16 pm
dang, dude. nice job.
Posts: 6876 Joined: Mon Dec 11, 2006 3:45 am
Post
by Waffles » Fri Jul 30, 2010 9:31 pm
Looks like a solid DIY start.
I think the ASR brace ads some torshion(twist) stability that the mild steel might not help as much with. I can think of a what to better support it other than thicker metal but that will add more weight.
Posts: 4601 Joined: Sun Jan 21, 2007 6:12 am
Post
by Phate » Fri Jul 30, 2010 11:24 pm
Waffles;240273 wrote: Looks like a solid DIY start.
Yep. Also, the asr brace ties together the front and back of the LCA mount as well.
Posts: 1097 Joined: Tue Nov 21, 2006 10:25 pm
Post
by 5thgen » Fri Jul 30, 2010 11:53 pm
how thick is that and what is it made of?
looks kind of thin.
IshbOO
Posts: 712 Joined: Thu Oct 04, 2007 3:49 pm
Post
by IshbOO » Sat Jul 31, 2010 12:33 am
well good work mounting everything, looks clean. But will that big sway bar still bend or twist your frame is the real question.
95 Silver JDM Fronted DC4 with B18c1 swap
94 Teal DC4
Post
by Capt'n Obvious » Sat Jul 31, 2010 1:06 am
well 10 bux is better than 200 or whatever and its more of an adapter than a brace
the itr sway dont fit on the stock si sway bar mounts as you can see
and how can it twist the frame with this set up i understand if it was mounted on stock mounts yeah but not if the mounts are tied together
Post
by Phate » Sat Jul 31, 2010 2:23 am
Capt'n Obvious;240289 wrote: well 10 bux is better than 200
Lol, until it tears out your subframe. Hopefully it doesnt though. Atleast you made it work.
