New project 89 CRX DX
CRX91
bought it tuesday for $550, one quarter panel is rusted, needs new wiring harness, heat system needs to be put back together, looking for a new stearing column, people i bought it from put and integra stearing column in it, has unbelievable wheel play on it, has a '91 SI swap on it, all wheel disc-brakes are on it, looking for a passanger side fender, and an SI front bumper. i'll keep putting pictures up here to keep you guys updated on the progress.
You do not have the required permissions to view the files attached to this post.
That's the nicest CRX I've ever seen.
CRX91
thanks for the support man i need inspiration. lol
crx08
I want another CRX. nice find! are you looking for a steering column from a integra?
stl-imports.com/forums
except his other one... That one is the nicest CRX EVER, rememberJustRob;214766 wrote:That's the nicest CRX I've ever seen.
99BlackHatch
:rolleyes:
SquadronOne.net
SquadronOne.net
CRX91
im looking for a 89crx stearing colum it has a integra colum in it and it has alout of wheel play. got a question there is oil were the spark plugs are warped head bad head gaskit what do you guys think.
tommygun89hb
if there is oil in the plugs below on the electrode part then it could be internal engine, above the threads on the white part of the spark plugs then it is the valve cover spark plug gromets. it is common on hondas easy fix if its on the white part.
CRX91
its a puddle its on all of thespark plug. but the thing is it ran really strong and when i took off the valve over to replace the gaskit put it all back together it has not ran it as today i think itsgust the plugs there bosh in it im geting ngk
gsrauto98
it's gonna be hard to follow your build because i think you might have the worst grammar and spelling ever!!! besides that good looking project you got there.
