What did you improve on your car this week?
crazysol
Just got back from vacation to find a new motor has been delivered to the house. Its so clean and ready for install.
Barn-Yard Built..
Lynxs1981
Started tearing down the tranny to replace the broken clutch case.
Edison Carasio
The Fit - Cleaned air filter (or was that last week? lol)
CRX - Rick tightened up hub/spindle nut or whatever that was causing loose wheel bearing. Had outter tie rod replaced.
lilryan
put on itr rear sway and asr subframe brace
hx swapped dx saloon
Bought a GSR block to start building
What???JustRob;241328 wrote:Bought a GSR block to start building
I'll have a motor ready for when the Jetta sells so I can pick up where I left off.Waffles;241329 wrote:What???
SikofFalln
Nice!JustRob;241330 wrote:I'll have a motor ready for when the Jetta sells so I can pick up where I left off.
Took the crap ass window tint off the back hatch glass (still have to do the rear quarter glass).
Replaced the dryer and the expansion valve on the A/C, cleaned the exchange, and replaced all the foam seals. In the next day or two going to vacuum out the system and give it a fresh charge so I will have some cold A/C again.
3-1-4
4Door
92'
A/C went out a few weeks ago (so much for an improvement)
98'
tightened up all the sub-frame bolts - no more pops and creaks when going up/down the drive way...
fixed a factory flaw on the SRP competition fuel rail i robbed from my B-16... they never drilled the hole for the FPR all the way threw, so it would just keep building pressure... pretty sure its why the guy drove on it for 20 miles then pulled it and i ended up with it for $250
that, and the AEM cam gears were out of wack...
i think im going to pull it apart and give it a refresh (rings, bearings, hone, etc;) and install the GSR cams, then finally put it in and pull the tired Ls out... ehhh, who knows...
98'
H.E.A.R.T
Martin
Got a 98 rear bumper and Spoon oil cap. Ordered new a Spoon rear strut tower brace. Installed my new Spoon blue rearview mirror.
______________
Eric
97 Cypress Green Integra Ls.
Eric
