Ok just for the record
subygrl
Oh man, that really sux. I'm sad for u!
2002 Subaru WRX-Pretty close to stock......for now
kra95civic
man o man its sumthing a noob like me will never want to c in person again....
o chris thanks for letting me help u i learnd sumthing 2 day.....if u need help in the up in coming days lmk im down for getting dirty and learning alittle....
SikofFalln
That sucks man. So are you going to get new pistons? Reason I ask is I have a set of new OEM CTR .25 overbore with new OEM rings that I may let go of. The only thing is they are pressed onto LS rods at the moment.
3-1-4
RSXSLVR79
all i have to say is damn.......
looks like hot fire is burned out for a while....
01 S2000 (Stock...for now)
dc2whore
sucks it happened but now its time for even bigger and better things
big pipe
Just found this and this is perfect for this thread
Yeah, that's kind of what I figured you'd end up finding. Mine looked similar but it was a valve stuck through the middle of a brand new JE piston and a head ruined that had 1500 in port work and mods. Sucks a lot. IF you need any parts, let me know. I have quite a bit of stuff laying around...
Jeebus thats nasty!! Thats really too bad.
thanks ryan appreciate that, dale and i are going to brain storm and do some part swapping from this block to my other good block (like crank and bearings.. other block spun a rod bearing but has perfect pistons and cylinder walls). So pretty much have to figure out a head and replacement valves... looks like i need two exhaust valves (if they are oem i have replacements) and then have it port and polished then reassembles it with the parts from this head and then put the motor back together again.RyanA;79555 wrote:Yeah, that's kind of what I figured you'd end up finding. Mine looked similar but it was a valve stuck through the middle of a brand new JE piston and a head ruined that had 1500 in port work and mods. Sucks a lot. IF you need any parts, let me know. I have quite a bit of stuff laying around...
but i will let you know if i need anything
chris
