Ok just for the record
subygrl
Post by subygrl »
Oh man, that really sux. I'm sad for u!
2002 Subaru WRX-Pretty close to stock......for now
kra95civic
Post by kra95civic »
man o man its sumthing a noob like me will never want to c in person again....
o chris thanks for letting me help u i learnd sumthing 2 day.....if u need help in the up in coming days lmk im down for getting dirty and learning alittle....
SikofFalln
Post by SikofFalln »
That sucks man. So are you going to get new pistons? Reason I ask is I have a set of new OEM CTR .25 overbore with new OEM rings that I may let go of. The only thing is they are pressed onto LS rods at the moment.
3-1-4
RSXSLVR79
Post by RSXSLVR79 »
all i have to say is damn.......
looks like hot fire is burned out for a while....
01 S2000 (Stock...for now)
dc2whore
Post by dc2whore »
sucks it happened but now its time for even bigger and better things
big pipe
Post by big pipe »
throw it in the gutta, go buy anotha
eazy-e
this space for rent
Just found this and this is perfect for this thread
Post by RyanA »
Yeah, that's kind of what I figured you'd end up finding. Mine looked similar but it was a valve stuck through the middle of a brand new JE piston and a head ruined that had 1500 in port work and mods. Sucks a lot. IF you need any parts, let me know. I have quite a bit of stuff laying around...
Post by Phate »
Jeebus thats nasty!! Thats really too bad.
RyanA;79555 wrote:Yeah, that's kind of what I figured you'd end up finding. Mine looked similar but it was a valve stuck through the middle of a brand new JE piston and a head ruined that had 1500 in port work and mods. Sucks a lot. IF you need any parts, let me know. I have quite a bit of stuff laying around...
thanks ryan appreciate that, dale and i are going to brain storm and do some part swapping from this block to my other good block (like crank and bearings.. other block spun a rod bearing but has perfect pistons and cylinder walls). So pretty much have to figure out a head and replacement valves... looks like i need two exhaust valves (if they are oem i have replacements) and then have it port and polished then reassembles it with the parts from this head and then put the motor back together again.
but i will let you know if i need anything
