whos in for pinks all out?
sloaccord20
Post by sloaccord20 »
Full length pants, shoes and socks are required
Helmets are required if you run under 14 seconds in the quarter mile. (snell 2000 or SFI 41.1A min
Driver Fire Jacket for all drivers in cars quicker than 12 seconds in the quarter mile
Roll Bar in all cars quicker than 11.49 in quarter mile
Roll Cage in all cars quicker than 10.99 in quarter mile
Chassis needs to be NHRA certified to run under 9.99 seconds
Driver must be NHRA licensed to run under 9.99 seconds
sloaccord20;98493 wrote:Full length pants, shoes and socks are required
dont forget about the shirt... gateway wont let you run with a sleeveless shirt. retarded.
and you also have to have a firejacket if you have nitrous or a turbo on your car that was not there from the factory.
Post by 5thgen »
I think a scatter shield too....at 11.99 or lower.
I've never been "tech'd" on that though.
Post by rickles8099 »
5thgen;98585 wrote:I think a scatter shield too....at 11.99 or lower.
speaking of scatter shields.... does anyone know where you can get one for a d series?
LowePerf
Post by LowePerf »
rickles8099;98594 wrote:speaking of scatter shields.... does anyone know where you can get one for a d series?
Worried about something Rick? :)
618-463-0224
LowePerf;98807 wrote:Worried about something Rick? :)
just worried about not passing tech when the time comes :)
oh and one day next week ill might be stopping by to talk some business :)
Fast S-10
Post by Fast S-10 »
Did anyone else sign up and get registered for Pinks??
sloaccord20
mike93hatch;98562 wrote:dont forget about the shirt... gateway wont let you run with a sleeveless shirt. retarded.
they let me run without a fire jacket and scatter shield
but my car isn't as fast as yours
racergti
Post by racergti »
Fast S-10;98964 wrote:Did anyone else sign up and get registered for Pinks??
I'm curious, too. I'd love to see a good representation of imports. I know there are some fast hondas toward KC and I hope they're giving it a shot.
The 'dubs will be out in force:
1-10 sec turbo '86 golf
2-11 sec turbo golfs-'98 & '00
1-12 sec motor '84 rabbit
Post by stolle »
from honda-tech and nhra rule book:
From the '08 NHRA rulebook general regulations 2:10 last paragraph (pg. 71).
All front wheel drive or transverse mounted applications using a clutch and running 11.49 or quicker, for which an SFI spec 6.1,6.2,6.3, or 9.1 flywheel shield is not commercially available must be equipped with a flywheel shield made of 1/4" min. thick. steel plate. Shield must surround bellhousing completly except for area of bellhousing adjacent to differential and axle shaft. Shield may be multi piece, w/ pieces bolted together using min. 3/8-inch diameter grade 5 or M10 class 8.8 bolts; may be attached to engine or bellhousing.
so you could probably just make one with 1/4" stock and some bolts. golden eagle makes one, but its $230+ so i think i would just try to get away with making one, if its allowed...
