88' Nissan Pulsar
lurch95hatch
88' Nissan Pulsar
that is a beautiful throwback car! GREAT pickup!
1995 Civic CX Hatchback (work in progress)
2001 Civic LX Four Door (stock as the day she was born)
crx08
88' Nissan Pulsar
use some fine sand paper for the cam lobes. razor blade to clean off the deck
stl-imports.com/forums
Edison Carasio
88' Nissan Pulsar
MMmmMM tasty.
88' Nissan Pulsar
Is it just me, or does that cylinder look not very round anymore?
88' Nissan Pulsar
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.Waffles;286179 wrote:That looks to be just the metal ring of the head gasket, not the actual cylinder.
Good eye.
delslo
88' Nissan Pulsar
Spot on!Waffles;286179 wrote:That looks to be just the metal ring of the head gasket, not the actual cylinder.
delslo
88' Nissan Pulsar
Just a Teaser. The head is back on with a fresh gasket, but I haven't hooked everything up yet. After I tighten everything up, I'll cycle some oil and some water to clean that nasty ho out. Then 50/50 the coolant, and a real oil change and likely seafoam.
tbrazzy-s3
88' Nissan Pulsar
:popcorn4:
2000 GSR
1999 Triumph Speed Triple (3cyl naked) -broken-
2000 Kawasaki ZRX 1100 (5spd naked)
delslo
88' Nissan Pulsar
Put on the new Timing Belt, tightened up associated hardware.
