diy asr brace and got a 22mm rear sway
luvmyhondas
Post by luvmyhondas »
like the concept, but don't 100% agree with the execution. only time will tell who is correct on whether or not that 22mm will tear the subframe or not. Hopefully, not.
either way, props for at least showing what you did regardless of what people say.
AKA audioguru76
The faster I go, the broker I get!
79 Hondas and counting!
speed
Post by speed »
Capt'n Obvious;240295 wrote:
you guys think you need to spend money for shit you dont need because you guys are swayed by marketing gimmicks
ROFLOL. Again with real performance parts being "marketing gimmicks".
U need to go back to tiburon world.
*flashes back to that diy paintjob on that poor tib valvecover.... on second thought nevermind. Heres a dancing banana for your sheet metal brace and your mad tight jdm "fab" skills :gotbootie:
Capt'n Obvious;240295 wrote: you guys think you need to spend money for shit you dont need because you guys are swayed by marketing gimmicks
willworkforhondas
Post by willworkforhondas »
speed;240455 wrote:ROFLOL. Again with real performance parts being "marketing gimmicks".
:assshake: :PDT_fly:
[Today 01:32 PM] rickles8099: if you dont like it, theres a log out button at the bottom of every page[Today 01:47 PM] rickles8099: willworkforhondas = god
Post by Capt'n Obvious »
this coming from the guy who painted random peices in his bay random colors lol
Andrew
Post by Andrew »
Lol.
I also don't see the need for the bigger sway bar on a dd.
kra95civic
Post by kra95civic »
OK first off MATT acctually does look into things before he does them. he may take more time to do so, but there is always a learning curve. I'm sure if someone wants to an asshole about it. and just pick on the guy who doesn't want to follow a cretin set up that everyone is using. it's his car let him do what he wants. you don't have to drive it, and you sure as shit don't have to look at it. also if he fucks it up he can find someone to help him fix it.
Matt the only thing i would change about you brace is to just use it as an adapter not a whole piece of metal. now the asr dose come with months and months of research to prove that it worked. im sure the asr started in the same fashion, and it took time and energy to get it to where it is today.
so when looking for metals next time sometime the cheapest metal out there wont give you the same aspects as a asr thats varies in sized for 1/2" to 1", and when it all put together its over 1 1/2" to 2" thick in places.
Capt'n Obvious;240600 wrote:this coming from the guy who painted random peices in his bay random colors lol
the random comment won't mean anything! You would have been better off just to ignore the dumb shit, and keep posting your discovery's of what you have found out. this is what you need to work on. end of rant.
Lynxs1981
Post by Lynxs1981 »
I hope it doesn't tear out. That 22 is a big step over stock, should make for good cornering.
Post by andyjt »
Lynxs1981;240607 wrote:I hope it doesn't tear out. That 22 is a big step over stock, should make for good cornering.
Pretty sure it will just bent the factory brackets his adapater brace is bolted to before it would even have a chance to hurt the subframe.
Dumb. The car needs struts before a sway bar.
modthesol
Post by modthesol »
kra95civic;240605 wrote:OK first off MATT acctually does look into things before he does them. he may take more time to do so, but there is always a learning curve. I'm sure if someone wants to an asshole about it. and just pick on the guy who doesn't want to follow a cretin set up that everyone is using. it's his car let him do what he wants. you don't have to drive it, and you sure as shit don't have to look at it. also if he fucks it up he can find someone to help him fix it.
we may have to drive next to it.
