ummm not really I have had 20+ hondas and not many of them had this problem so how is this typical? But whatever just curious.freakchris03;24475 wrote:typical honda problems...
This sucks
This sucks
Silver Knight
This sucks
Aj, you've never had a car long enough to fix something if it had a problem!soundqjr;24478 wrote:ummm not really I have had 20+ hondas and not many of them had this problem so how is this typical? But whatever just curious.
DC5
This sucks
Actually yea I have. I just keep car for 3 months and then sell. But alot my cars have had problems. But I have never had a bad head gasket yet.Silver Knight;24480 wrote:Aj, you've never had a car long enough to fix something if it had a problem!
This sucks
Silver Knight;24403 wrote:no i'm not throwing a code, at all. as for my oil, i just checked it and there was nothing on the dipstick but i just got it changed like 1,000 miles ago. My oil lamp isn't even coming except for when it first starts which is normal anways. me, josh, corey, chris, and rob all checked it on sunday and it showed that there was plenty on the dipstick and now it is showing nothing at all. my car is really starting to piss me off.
The sensor only turns the oil light on when the pressure is below 4psi. Pretty stupid IMO. In my y8 before it started knocking it had well under 1/2q when i drained it out and the oil light never came on.
This sucks
pretty stupid to let your car run that low on oil. im 98% its a head gasket. on hondas that seems to be the only place that would leak oil into your coolant. gm v6s have a bad time with lower intake gaskets that cause the same issue, but hondas dont work the same. just do the leak down test before you rip your water pump out, its well worth the time.andyjt;24580 wrote:The sensor only turns the oil light on when the pressure is below 4psi. Pretty stupid IMO. In my y8 before it started knocking it had well under 1/2q when i drained it out and the oil light never came on.
