X2 Alot of cels will put your car into "safe mode"SilverStreak;124074 wrote:You need to figure out why the check engine light is on first. That will most likely fix your problem :doh:
need to read the rules again needing teg help!
00gsr
2000 Milano Red Acura Integra - B18c1
|Ground Control|A'PEXi|PasswordJDM|
01civiclx
Hey i had that same problem with my 1996 integra gsr, try checking the map sensor and possibly the throttle cable. Pretty sure that will fix it
slammeds2k
Listen to the cel light man its your friend get the code look it up fix the problem... In most cases
