need to read the rules again needing teg help!
00gsr
Post by 00gsr »
SilverStreak;124074 wrote:You need to figure out why the check engine light is on first. That will most likely fix your problem :doh:
X2 Alot of cels will put your car into "safe mode"
2000 Milano Red Acura Integra - B18c1
|Ground Control|A'PEXi|PasswordJDM|
01civiclx
Post by 01civiclx »
Hey i had that same problem with my 1996 integra gsr, try checking the map sensor and possibly the throttle cable. Pretty sure that will fix it
slammeds2k
Post by slammeds2k »
Listen to the cel light man its your friend get the code look it up fix the problem... In most cases
