wiring up claytons drag car.
Edison Carasio
Keep up the good work.
delslo
very nice!
Clayton
looking good my friend
luvmyhondas
looking good. funny how some folks are so intimidated by wiring and others are not.. Also, it's amazing how much of a difference just a little loom and heat shrink will change the look of that harness.
AKA audioguru76
The faster I go, the broker I get!
79 Hondas and counting!
thanks everybody! here is a not so good installed pic.
Boosted_da
looks good!
thanks man!Boosted_da;292681 wrote:looks good!
got the switch panel wired up, went to test fire and the battery was dead.
switches from top to bottom:
1. ignition
2. starter button
3. main power: ecu, injectors, gauges, sensors
4. fuel pump
5. fan
6. used to check engine codes, turn the switch on and the light will flash trouble codes.
the first fuse in the panel isnt used, so the car runs off of only 3 fuses not counting the fan, oh and only one relay!
Boosted_da
whats the motor setup going to be on this thing? pending i might have a few parts i would be willing to donate.
looks good stolle! i like the CEL switch idea.
Racecore.com
Racecore.com
Clayton
car burnt down in stolles garage last night r.i.p.
