http://www.vadriven.com/forums/showthre ... 025&page=1
check this out
new fuel pump new relay still wont start
tommygun89hb
gcef89
im gonna work on it again tomorrow will post what happens!
gcef89
so fuel pump is on running had a lose wire but still no fuel to fuel rail could it be fuel pressure?
did you ever put more gas in it?gcef89;270232 wrote:so fuel pump is on running had a lose wire but still no fuel to fuel rail could it be fuel pressure?
gcef89
yes sir has roughly 4 gallons and still nothing
is the car sitting on jack stands at an angle? other than that if the fuel pump is running theres only a few things i can think of a severely clogged fuel filter, no fuel or not enough fuel in the tank or the short piece of hose the connects the pump to the sending unit has a hole or has come off. i think you have already addressed the first two conditions.gcef89;270245 wrote:yes sir has roughly 4 gallons and still nothing
have you checked your fuses, i would go through all the important ones. does it even sound like it wants to start?
gcef89
no car is not on standsstolle;270249 wrote:is the car sitting on jack stands at an angle? other than that if the fuel pump is running theres only a few things i can think of a severely clogged fuel filter, no fuel or not enough fuel in the tank or the short piece of hose the connects the pump to the sending unit has a hole or has come off. i think you have already addressed the first two conditions.
fuel filter is only about 2 months old
id figure 4 gallons would be plenty?
and are you talking about the hose on top of the fuel pump?
MasterTech95
did you check you clutch safety switch on the top of the clutch pedal?
gcef89
anyone have a diagram of the air hoses running to the fuel tank?
gcef89
i guess im going to switch out all the rubber hoses maybe one is cracked hope it works!
