mike93hatch;147706 wrote:what makes a syncro bad?[/QUOTE
Excessive wear I guess not sure I read it in a s2000 review in a mag. Well tell me this why is it that i can have the clutch in while rolling and can move the shifter to just the right spot between the gear (not forcing anything) and it will gring everytime. I have tried bleeding the system time after time no change... You said your good with trannys so if you could help that would be awsome
Carbon Coated Sycrons
slammeds2k
not referring to you. i was referring to the OP. OEM syncros work great. when you start tossing aftermarket parts on cars, you get aftermarket problems. kind of like people rocking aftermarket LCA's with a stockish rubber bushing that lasts 1/3 of the OEM bushing's life.slammeds2k;147687 wrote:not sure if your talking to me or not but the tranny in my car is known for having bad syncros they corrected it on the next jen with carbon and stronger internals
slammeds2k
Yes especially cheap aftermarketbildo16;147749 wrote:not referring to you. i was referring to the OP. OEM syncros work great. when you start tossing aftermarket parts on cars, you get aftermarket problems. kind of like people rocking aftermarket LCA's with a stockish rubber bushing that lasts 1/3 of the OEM bushing's life.
every standard shift car i have drivin does thisMiggyp17;124302 wrote:oh serously?
i have a d16z6 with some tranny its cable and an si and im not sure but
if im going and im getting close to a stop sign and i try to put it in 1st it just like doesnt wanna go
and 5th sometimes pops out and you have to literly jam it in there
any ideas?
