Need some History on a Local CRX
sharpie
Post by sharpie »
I have an itr fuel rail with injectors and oem fpr on it sitting in my garage is you wanna give them a try pm me
Fzn14
Post by Fzn14 »
sharpie;292095 wrote:I have an itr fuel rail with injectors and oem fpr on it sitting in my garage is you wanna give them a try pm me
I might have to take you up in that offer. Let me see how it does with the adjustment
rccivic
Crx
Post by rccivic »
I owned it for awhile.when I got it it was a tooth off on timing so I re did the timing and it always ran rich.they also put obd1 injectors an took out the resistor box for some reason.and it does not have aftermarket cams.they also put a header Onit an only had one o2 sensor not sure it that was ever fixed.some kid from Ill side owned it hope this helps
Post by RyanA »
onecam12sec;292074 wrote:i installed the resistor box, since it was runnin w/o one. had obd1 240cc's, and might wanna try another virgin ecu, and see if it resolve the rich issue. in the mean time, donnot light a match near the exhaust. lol
Why would you add a resistor box to OBD1 injectors? OBD0 are low impedance and OBD1/2 are high impedance. Adding resistor box just makes them high high impedance.
Or am I reading what you said wrong? IF it has OBD1/2 injectors and a resistor box, that is a problem right there. Doubt it's the rich problem but it is a problem.
Fzn14
Post by Fzn14 »
RyanA;292547 wrote:Why would you add a resistor box to OBD1 injectors? OBD0 are low impedance and OBD1/2 are high impedance. Adding resistor box just makes them high high impedance.
Well with all that. This thing is up sale. Found out i need more money for the house. If anyone is interested please contact me. Looking for 2800 OBO And or a even trade depending on the car
