Project: HRDPKR
Project: HRDPKR
Looks great Chris. You got work done while I was gone.
99BlackHatch;203042 wrote:Looks good Chris... When can I get the hatch in there for a few days to paint and tuck the bay!?
:biggrin:
Nerrej;203044 wrote:After me! Take a number pal! lol
F that. I have AJ's car and my car to finish after Jerren's. We're booked LOL
Project: HRDPKR
Post by N2HIFI »
UPDATE:
-pick my motor up from dale fully rebuilt and ready to rock and roll again
-mounted the clutch,flywheel and PP
-mounted the tranny
-installed alt and misc. accessory brackets
-worked on the engine harness for the wire tuck
pictures of the engine harness mid modification
still have to finish up the drivers side of the harness , but i can knock that out in a hour or so and then the motor will be ready for reinstall
Project: HRDPKR
Post by Capt'n Obvious »
i wish i had 4 cars to choose from even if 2 are down
well i got the sam ratio 1 down 1 runnin
Project: HRDPKR
Post by N2HIFI »
matt;204332 wrote:i wish i had 4 cars to choose from even if 2 are down
yea i am super lucky that i have the 240 cause without it running i would be screwed.
Project: HRDPKR
Post by N2HIFI »
Update:
Ok finished the harness, the tuck and put the motor back the fuck in lol
finished harness and pigtail
pile of leftovers
okay motors in
some closer shots of the tuck
quick pic of the power distribution inside the car and the ecu side of the pig tail
Okay major hurdle out of the way ... now i just need to finish the following
-axles
-Header
-The correct VC needs to be put on still
-Shifter linkage and new shifter bushings
-Exhaust
-Intake
-Fluids
-Oil pressure gauge (wires are ran in the harness just need to mount it and get power)
-Mount battery and hook it up
-Reinstall bumper
-Test Drive
-Clean the fuck out of the bay Cause its DIRTY
I still have ALOT of clean up work that needs to be done on the bay, needs new bolts and hardware for alot of the mounts and stuff, need to upgrade the mounts OR pull them and paint them, need to go pick up the rest of the firewall plugs which did not come in yet. Need to put the header on and then take it to the muffler shop to modify the mid pipe to make it fit the new header setup. Then once i finish that BS ill be alot happier
and on a side note .. i know that all the baller cars on honda-tech either pay for a chase bays harness (roughly 500.00) and use alot of mil spec coatings and other styles of coverings but i'll be very honest, i suck at depining things and i had all the look heat shrink and tape at work for free soo yea......
modthesol
Project: HRDPKR
Post by modthesol »
skills
Project: HRDPKR
Awesome progress. Sorry I couldn't help last night.
sharpie
Project: HRDPKR
Post by sharpie »
big difference from when i saw it the other day keep up the good work
Project: HRDPKR
will i see this at starved rock
tbrazzy-s3
Project: HRDPKR
Post by tbrazzy-s3 »
looking good, wiring frightens me. just saying
as far as the continued bay clean up goes. it looks like a few samco silicone hoses (or something similar) would help with the clean up quite a bit. also, you (or anyone) ever taken a look at some of the stuff 'killer glass' does? I'm kind of iffy on it.
