no problem, once its clean it pretty easy to touch it up when you wash your car just using some towels and car wash soap or quick detailer. im only saying this because i screwed up and did it, do not use purple power to clean aluminum, you wont like the results! only use simple green it works well and it wont damage the aluminum.lurch95hatch;295429 wrote:Wow, thanks! Just what I wanted to hear. Thank you stolle:hail:
some other things i do, use balls of aluminum foil and wd-40 to clean chrome and stainless also works well getting corrosion off aluminum parts and the foil contours the shape your working on. it doesnt scratch the surface as much as steel wool or a red scotch brite pad can.
