Working on you car BLOOPERS
Kolk1
How about, I took my car to next level, they shut down, I had to use to the cops to find my car in a storage center, all to have it taken to Light speed to get finished where it was completly stripped by a thief (supposedly).
1 Hyundai + 1 Kawasaki = 558whp 519wtq
tmarsh
tried jacking up the gto on a non-supporting crossbeam....it's frowning at me now.
luvmyhondas
only one I can think of right off the top of me head...i started my HMT style turbo'd hatch with 550cc injectors and a stock ecu...had gas soaking the exhaust manifold!
Oooh, how bout this. putting a set of aftermarket LCAs on a 96 civic coupe. Didn't notice that the box I got was for 92-95 civic. Damn near had them on there before I realized that and gave up. talk about 40* positive camber!
GTI-Guy
Ouch, but a ton of us have come close to that ... saw it happen to a car on track at speed06sik20z3;181779 wrote: dumbest thing i have ever done was got to excited and did not tighten the lugs drove it out the garage herd that dreaded noise tried to bring it back in but boom fell right on the rotor
The Track Is Where It's At! Upcoming events at
hacstl.com/forums/showthread.php?t=62897
GTI-Guy
Don't you love how angry you can get at yourself when dorking up like that. If you know someone with a winch and get creative, might be able to straighten up a bittmarsh;181825 wrote:tried jacking up the gto on a non-supporting crossbeam....it's frowning at me now.
Strativarious212
Was working a bit quick and on 3 cars at the time. put oil in one of the oil changes to find out that I didnt put the drain plug back on <.<; ... Also was doing a tire repair when i first started working. someone tweaked out the buffing tool so as i held it on the spot it ate it down to the steel belting. funniest thing to ever happing to me wial working on a car was when I took a step back and bam forgot there was a tire there... yeah everyone in the shop laughed at that one only to then get shot in the face with gasoline as i pulled off one of the fuel hoses from the fuel pump. (FYI i was droping the gas tank to replace the fuel pump)
chunney
I made a pretty dumb mistake doing my last oil change. Accidentally dropped the new filter down into the bucket of old oil.
zacs2k
I ordered 1.5mm lugs for the s, figured they would send the right size so w/o looking at them I put them on. I did realize it was a tight fit but i wanted them on so bad i just said fuck it.
After I got them on, i realized they were 1.25mm lugs.
stlgolf.net
kikkinasphalt
while replacing the clutch in my probe GT i installed the transmission and neglected to put the new TOB on the input shaft.
had to pull the trans back out of the car.:PDT_att:
'98 CSVT.. stock
Nat X
/\ I've done thatdelslo;181718 wrote:Recently, I did oil.... forgot to put cap back on and drove to work.Messy and Smokey.
I used to forget arighty tighty some times, its has cost me some money :kermit:
your locally famous internet superstar.... RESPECT
