Unknown Maintenece History
heh, that's alright. I don't post much about any of them because there isn't ever much to post.
but because you said something, I will post a thread in the next few days.
Martin
Post by Martin »
I will take a look then. Always enjoy looking at what other folks are up to.
______________
Eric
97 Cypress Green Integra Ls.
mike93hatch;193725 wrote:although honda says to change the manual trans fluid every 60,000 miles.....mr. spoon himself (Ichishima Tatsuru) says it should be strictly changed at every oil change.....at least on modified hondas driven to extremes and not some daily driver.... i change mine every oil change on my blue hatch...
A very good idea IMO. Changing the transmission fluid is just as important as the engine oil. A LOT of people over look that.
JustRob;193795 wrote:A very good idea IMO. Changing the transmission fluid is just as important as the engine oil. A LOT of people over look that.
especially in a automatic!
Martin
Post by Martin »
Woot got it all fixed..........crap now I am broke for a little while, but I feel better now that its done lol.
______________
Eric
Foxcow
Post by Foxcow »
I'd change the O2 sensor and make sure the CV joints look good.
Martin
Post by Martin »
Foxcow;194627 wrote:I'd change the O2 sensor and make sure the CV joints look good.
CV joints checked out fine, dont know about the 02 so I'll probably change it out to. Thanks.
______________
Eric
SweetEBPSi
Post by SweetEBPSi »
If your not getting any O2 sensor codes, then leave them. Why change something that isn't broke? O2 sensors can be expensive, depending on which one you buy.
irevto9k
Post by irevto9k »
hmmm not sure if you really need to change the trans fluid that much if your
useing quality fluids i cant see it breaking down quiet that fast
F>B+K ALL DAY :respect:
irevto9k;194753 wrote:hmmm not sure if you really need to change the trans fluid that much if your
You wouldn't think so, but it does. The transmission more moving parts then the engine and is equally important. With any ATF fluid application, you make a good point. ATF is designed to last much longer then standard oils. But anything that takes normal gear oil or Honda MTF, it is just as important to change as your motor oil.
