rusty rotor bolts
rusty rotor bolts
RyanA;187548 wrote:Yep, impact driver FTW. If it's super PITA, take a torch and heat it up a little first. Then, get the correct sized bit, put it in the impact driver. Push down a little and smack it with the hammer. A couple blows is usually all it takes. Buy the one that has lifetime warranty on the tips as I have broken 3 of them in the last 6 months.
or you can get a set of like 50 of them bits on ebay for like $5 like i did lol
muha22752
rusty rotor bolts
Post by muha22752 »
ill deff have to go get one soon
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
Sleepy Civic DX
rusty rotor bolts
Post by Sleepy Civic DX »
I will lend you my hand impact if you come get it.
If you have stripped them out, try to cut notches in the set screws with a cutting wheel or a dremell. Then you can use a standard screwdriver (flat head) bit on the hand impact to try to get them loose. I would try this before drilling.
Good Luck.
2009 Black Mugen Fit- Slow
ejtuner88
rusty rotor bolts
Post by ejtuner88 »
oh yea. those impact drivers are awesome for that. i had the same problem with the rotors on my civic. bought one at o'reilly and it worked great. but a torch does help too
rusty rotor bolts
Post by Capt'n Obvious »
hf sells impact drivers for 5 and it does bolts too
so cheap i gave one to kevin and bought another one
