it first gear it kinda seems bogged down on take off...Waffles;267127 wrote:Is it sluggish to rev up?
where is the iacv? and i dont have a rpm gauge...stolle;267128 wrote:start the car let it get to temp, turn the car off, unplug the iacv. start the car it should idle around 600-700 rpm it should tell you what rpm its suppose to be on a sticker on the under side of your hood. if it doesnt idle, your idle is way off and should be adjusted properly.
nevermind i found it
would it need to be cleaned by chance?stolle;267128 wrote:start the car let it get to temp, turn the car off, unplug the iacv. Start the car it should idle around 600-700 rpm it should tell you what rpm its suppose to be on a sticker on the under side of your hood. If it doesnt idle, your idle is way off and should be adjusted properly.
